Is there a difference between the VP44 on the 2001 HO motor and the 235 hp motor? I just had my 3rd VP44 (covered under shop warranty) and it seems like the truck is not making as much hp as on the previous pumps? :{
What's new in the ETH engine:
Electronic Controls: New ECM calibration and fueling algorithms.
Fuel Pump: Increased fuel flow in the Bosch VP44 injection pump.
Injectors: Designed to provide increased fuel flow.
Injector note posted to the TDRoundtable by tgbol:
ETH injectors (3946306) flow 600cc at 100bars for 30 seconds
ETC injectors (3944828) flow 640cc at the same test.
Turbocharger: Revised wastegate setting for 26psi at the turbocharger outlet.
Manifold boost specification is 43. 5 inches Hg / 21 psi
Head: Valve seat inserts for added durability.
Pistons: New pistons with higher 17:1 compression ratio.
Flywheel: New flywheel with 330 mm diameter clutch (vs. std. 310 mm).
