Yes, The aftermarket cover is MAG-HYTECDiesel Nut said:Nice. I have the Severe Gear in mine. Great oils! Do you use an aftermarket cover?
Bertram65 said:What is that susposed to show? If the truck has been sitting for 24 hours or so all the sediment will settle to the bottom, it is not like engine oil where the stuff is held in suspension, anything from the diffs will be iron and drop right out. You should also point out that Amsoil no longer makes the series 2000 gear oil and a number of people have reported on the TDR having gear noise in the AAM diffs with anti spin when using that oil, most also reported the noise when away when it was changed out.
I'm quite sure your truck would have the 11. 5 AAM axle. You would need about 4 quarts to fill if you have the standard cover.WRStrong said:I am planning to change my rear diff lube to Amsoil Severe gear 75-90 in a few days. I can't find any information on the fluid capacity. The rear axle is anti-spin but I don't know if it's 10. 5 or 11. 5 AAM model. Does anyone know how much oil I can expect to put in the diff?
Anyone else experiencing noise or other quirks using Amsoil with 2003 anti-spin?
Turbo Thom said:Amsoilman... ... ... You'll have to forgive bert. He's from the NewEngland area and still believes Ted K is the best choice for President. So you can see his belligerence toward the oil. Forgive him my son. He was just raised that way.
. . Preston. .
