I have an axle truss for the front end that has a heavy duty diff skid plate on it. It is made by Con-Ferr. You can find it at 4 Wheel Parts.
http://www.4wheelparts.com/product2. asp?imseqn=895&occlass=CONSUS&cat=SUS
It comes with a gold finish which it promptly painted a flat black.
The problem with the back diff is that most of the time the sway-bars get in the way. Plus if you have a MagHytec rear diff cover it's just an added complication.
You can see pictures of mine installed if you click on "my truck" in my sig line.
Berserker
99 2500 QC LB 4x4 Auto, Laramie SLT, driftwood. Cummins 24v w/ 275 HP injectors, Edge Products EZ & Banks Stinger Plus kit w/Ottomind, Stainless Steel fuel lines, EGT and Boost gauges on A-Pillar mount, Prime-Location fuel filter kit (removed pending outcome of testing), MagHytec Diff and Trans covers, ConFerr front heavy duty axle truss w/skid plate, EZ Change oil drain plug, BFG 35x12. 50x16. 50 MT's, Tuff Country 5” stage II lift-kit, Rhino liner, Smittybilt nerf bars, Warn chrome Transformer brush guard w/Warn12000 winch, Tow Hooks, Xenon fender flares & Abbott Electronic Ratio Adapter. DTT's Valve Body & Torque Converter.
MyTruck
