Differential Temperature Question
sps66 is a whistle pig!
Old style lift pump?
Differential Temp Question
I recently bought a Mag-Hytec rear differential cover which has a pre-threaded NPT port for a temp probe. I was considering putting a temp sender in the diff, but realized that I had no idea what normal operating temps in the differential are (loaded and unloaded).
Futher, I'm not sure if measuring the temp in the differential provides any additional information that that of the trans temp (which intuitively should be the temp limiting point in the drive line).
What do you guys think. Any information would be greatly appreciated.
- Jason
The Dana 70/80 axles run higher running temps than the A/axles. Normal 100/180 anything 215 or over with 75/90 synthetic ,I would look into (Why).
