Dip stick marks?
Air Induction Question-
Looking for 97' instrument panel cluster bezel.
My transmission dip stick is marked with a Min point, a cross hatched area that says OK, and a Max point. No idea from these markings about how much to add to move the level up a certain amount. Do I had a quart when it's at Min? A pint? A quart? A gallon? or what? Does anyone know? I know how to check it ok, but have no idea what to do if it's out of range. I can just pour some in and go for a ride until it's at operating temp and see what happens I guess.
Joe George
Eureka, CA
'95 2500 CC auto 4X4,3. 54,Combo EGT/boost guage,custom switch panel,PacBrake,TST #5,BD valve body,Automatic motorhome steps on both sides,Foldacover hard bed cover,Cummins chrome kit,Black steel grill guard,Front hitch receiver
Joe,I put in a quart to get the level from the min hole to the top of the crosshatched area with the transmission hot. Only time I've had to add ATF was the only time I let the dealer service the transmission.
95' 25004X4,AT,Driftwood,Banks Stinger,Warn fender flairs and running boards(Play truck)95 3500,5 speed,Driftwood,Banks&Phscotty,34,000 GCVW apple and tractor hauler(work truck)
Thanks Bill,
Mine is about halfway between the min mark and the cross hatched area. I replaced a leaking pan gasget and lost a little. I guess I'll leave it alone then. It would be nice if the crazy thing was marked in pints or quarts. I didn't want to overfill it but had no idea how much was needed to bring it up to the ok part.
