DiPricol gauges
Stanadyne pricing
anyone have any experience with that bully dog exhaust?
Anyone know a web address for DiPricol gauges?Thanks
'97 Ram,automatic,3. 54 limited-slip, 4x4,smoothie,BD fuel plate,Prime-Loc.
Be aware, the DiProcol EGT gauge from TST is almost impossible to see the needle at night. The boost gauge needle is lit. The 2 gauges are not identical in appearance but very close and are ok if you are not really fussy. The poor EGT needle is my only complaint
96 SLT Laramie CC 5spd, 3. 54, no muff, no cat, 5"turn down tip
80gal fuel capacity. BD Brake, EGT,Boost + fuel pressure gauges. Member NRA/USPSA
Deezul 1,thanks for info.
I have the same problem with the boost guage lighting unless the dash lights are turned up max, wired them to go up and down with dash lights as I do ont like real bright lights at night, getting old I guess. . Then it is still not as easy to see as the boost and transmission temp. They have different lighting and are great.
96 2500 4x4 Driftwood auto Waren 4x boards pyro,boost,trans temp on a piller mag hytec trans
[This message has been edited by TRACY MURPHY (edited 11-28-2000). ]
Anyone know how to get a fuel pressure gauge from DiProcol?
'01 BLK QUAD-CAB, ETH, 6-SPEED, HX-40, DD BOOST MODULE, STAGE III INJECTORS, ATS MANIFOLD, 4" EXHAUST, BED LINER, CLARION PPD KICKER FOCAL STEREO
