There are two ways to work around uncooperative dealers who won't take care of their customers.
#1 lf you unplug the integrated brake controller, Dodge will indicate "TBC Fault" on the instrument
cluster. Some Dodge dealers can deprogram this feature. Most Dodges after 2008 splice the
wiring harness, leaving the integrated brake controller powered on, but with the integrated brake
controller's output wire disconnected.
For splicing, look for these wire colors on Dodge. Confirm with multimeter before plugging in
MaxBrake last. Dodge Purpose MaxBrake smallBlack -Ground White
Big YellodRed +12Y Black
smallWhite/Purple Brake Pedal Switch Red (Not needed for MaxBrake)
Big Green Out to Trailer Brakes Blue
Note: Only one brake controller can be connected to the trailer brakes at the time, so make sure
the unused brake controller's output wire is completely disconnected
#2. If you cannot have your integrated controller disabled by a dealer, I have been informed that you can do this.
To keep the computer thinking all is okay with the factory controller run a 12Ga wire from the positive side of the battery to the blade terminal that had 12v power supply. An in line fuse 5-30 amps is a good idea. Figure out where the black wire on the cable provided would associate with on the controller. Run a 12Ga wire from the battery neutral side to the neutral blade on the factory controller, this relates to where the white wire on the cable provided would associate with on the controller. Basically you are keeping 12V and neutral to the factory controller making it think all is okay.
These 2 suggestions have worked for other Dodge owners. Hugs, Di
Asked dealer to disable brake controller on signature truck I was told they can not do this. I was sure that I thought I had read posts that members had gone to dealers to disable the factory installed integrated controllers. Dealer said no way to do this - is this right?
I also had read a post on a way around this, but I can not find it. I prefer to have it disabled but, if it is not possible I may have to go that way.
If you have had a factory installed controller turned off please let me know how and where!
Tired of "STAR" bull****!!!!!
