I can tell you this...
the 3-piece (per side) caliper mounts (1 "
H" plate, 1 "
C" plate, and 1 "
(" plate) are
EXACTLY what are provided in the EGR rear disc conversion kit.
In addition to their $394. kit price (caliper mounts, hardware and rotors) you would have to add $300. for the two calipers with emergency brakes, plus $50. for the two 8" braided stainless steel brake hose extensions.
However, that does not address the E-brake installation kit EGR provides or the 16 modified wheel studs they also provide (
* : Earlier this week I discovered that the 16 modified wheel studs I received from EGR were basically crap! You see, the counterbores machined into the rear rotors were . 950" dia. (x . 110" to . 150" deep... measuring all 8 counterbores in 1 rotor). The OD of the wheel stud heads were 1". EGR decided their best course of action was to back grind (by hand, using a bench grinder
) the head, chamfering approx. 1/2 the head thickness to allow it to
"start" in the counterbore when being pressed (or beat) in.
Not good! [BTW, there is
no room for shank
"movement" of the stud as it registers in
both the rotor as well as the hub. The
front wheel studs only pass " somewhat loosely" through the rotor, registering into the hub/bearing assembly. What does this mean you say? There is
NO room for movement or any kind or tolerance per 'se.
My fix? I purchased another 16 studs (locally) and had a friend turn down the periphery on the heads (parallel to the stud shank... unlike EGR) to . 935". This worked great however, it was discovered by my friend that the centerline of the head was not always on centerline with the shank... at least not on all the studs. Irrespective, although a few of them (roughly 5-6 of them) appeared to be turned
off center, they were actually being "trued up" (to the shank centerline) and they ended up installing much better than the EGR supplied counterparts.
BTW, the complete rear disc conversion kit price from EGR is $995.
Just like they always say...
if ya want something done right you have to do it yourself!
