Philip,
The old bearing was exactly what I needed. I will post the part numbers as soon as I can for future reference. I did leave the ABS valve in for now. I had a bit of a time adjusting the parking brake levers. They are kind of a PIA. I think I still have a very small amount of air in the lines, but I will tackle that tomorrow when I rotate the tires. I also have to replace one wheel stud as it stretched out on me. The pedal is nice and consistently firm. But like I said, I just want to make sure there is no air in the calipers. It sure is easy to see the rear seals now. It will be easy to tell if they ever start leaking again.
BTW, I found a nice $2. 00 tool for installing speedi-sleeves. I went to a hardware and bought a piece of PVC pipe adaptor. It is made to slide over a 3" pipe on one end, and is threaded on the other end to screw a cap on. It fits the speedi-sleeve lip perfectly. I just used a really small ball peen hammer to drive them on.
Have you done much else to your truck?
Jeremy
