fuse??
You are correct there is no easy removable fuse for the heater grids!! The best thing to do is remove the connectors from the battery cables. The feed wires to the solenoids run to PDC then to the pcm and it controls the run time. I heard and seen about the oil switch but if it was me and I don’t mean to step on anyone’s shoes but it is more quicker to remove the connectors from the battery than more wires and concerns to go wrong later. It takes me 30 seconds to remove them and hook them back up. It does not set codes or change engine data. I have been doing this for sometime now with complete success. I have looked at the engine data with no concerns or seeing any effects from it.
