Originally posted by WadePatton
Graph: I'll try to get my curves into electronic format.
F1: some cars make more the 16000 R's -- gotta love that pnuematic valvetrain!
Hohn: While we're into TQ/HP lessons, what are the reasons for the variations in RWTQ we see for a given power level on the 5. 9? Is it in the dyno, the software, the operator, the driver, the mods, or my bet-the engine itself? And which number would tend to be more accurate?
thread hijack underway![]()
Lots of variables, Wade. Too many to list. And we all know that these trucks vary quite a bit in stock tune. Nevermind the HUGE differences between 12v and 24V trucks.
I think the dyno you want depends on what you are looking for. For towing performance, use a load dyno that measures torque and calculates hp. For acceleration, use an intertial dyno, measure hp and caluclate tq. That's what the NASCAR boys do.
You can tell a LOT about an engine just by seeing where in the RPM range the peaks fall, and how high those peaks are. For example, if I have a hopped-up gasser that makes peak tq @ 5200 rpm, I know that it has NO bottom end torque to it. Moreover, that tq# will likely be very close to the HP number.
Me, I want my peak tq rpm to be low in the rpm range, and for the peak HP value to be high in the rpm range. If a bone stock ETH (rated at 245hp) had a flat torque curve all the way to 6500rpm, you would have a 625hp engine!! But it wouldn't necessarily tow any better.
Here's an example to show why HP numbers are misleading: Imagine you have a Pro Stock drag car, which revs to 10K rpm, and produces about 1500hp. Now imagine that the engine was fitted with a ONE TON flywheel! Yes, a gross exaggeration to prove a point. This super-heavy flywheel keeps the engine from revving quickly. Now, take this 1500hp car, and run the 1/4 mile. Guess what, it's SLOW! Now, we have one problem: the number won't add up. We took our dyno-proven 1500hp car to the track, and ended with a pass where our numbers add up to a lot less hp! A high 6-second pass took 15 seconds. By the timeslip, our HP is only 300ish. How did our 1500hp engine only give us a 300hp pass???
The flywheel, obviously. The point here is that HP is a measure of the RATE you can apply FORCE. It's not a measure of the force itself. If the engine revs REALLY slowly, you can't do work (move the car down the track) very fast-- thus you have less POWER. The difference is stored in the flywheel.
BUT, not so fast. We now have all this stored energy in the flywheel. If we were headed uphill, this will help us to maintain momentum up the hill.
Whenever you think POWER-- think time. Torque is FORCE (and distance). Force=Mass*acceleration. So TORQUE causes acceleration? hmm. Yes, it does.
Now this is where it gets confusing because acceleration is a rate, right? like feet/sec^2? Well, don't get ahead of yourself. The F=MA equation basically states that applying a force to something will cause it to accelerate. Doubling that force doubles the rate of acceleration.
Work is what confuses people because it is both linear and rotational. you push a car 10 feet, you've done work. You turn the wheels on that same car until it moves 10 feet, you've done the same work, just in a different way. Work and torque have the same units: distance and force.
Sorry to rehash all this crap that you've all heard before. I guess I'll sum up by saying that HP wind the "paper" argument, Torque wins in the real world.
Justin
