This is not good
not good at all
Went to work to day every thing fine ... worked my 12 and fired the girl up to take me home . .
Checked gauges all green so I pulled out under normal acceleration and noticed a slight miss like the Tack would drop 1 line then pick right back up pretty quick ... .
Huh
Well it keep doing it under normal acceleration it would increase about 5 RPM then Drop 1 then over till I reached the MPH I was aiming @ then it would drop down 1 Rpm then jump up over and over about 3 mins between ... . I hit cruize @ about 60 and it still did it ... ...
I was running the comp on 3x4 so I turned it off and it got worst .....
Just about home and things get ugly ... . loss power then picked up FP is 15
then droped off big time almost died and threw a Code got back ahold of her and pulled in to the drive way started up my hill and NO POWER ..... No Power at all I am watching my gauges and I see my temp gauge start rising and rising fast before it went in the red all the way I killed the motor ... got out to check cooling looked good
Got back in fired right up then I made it up the hill missing like hell around the bend then was running out of power again and the Temp gauge was climbing Killed her again.....
Now its out in the drive way BRoke Down ... .
I need a Reader Guys Im working 4pm-6am the next 2 days if anyone is local and has a reader please call me @ 342-7645 And I will get out of bed and go W/O sleep if you can come over so I atlest know where to start I cant get my codes read because Im broke down
Sound like the VP$$ is dieing And the Temp was rising because of no fuel I dont know I need help Badly ... . I have to get some sleep So IF no one wakes me up I will be back on here as soon as I can .
TDR please come though For me
$2000 Suncoast Tc and VB will be here tues day
Looks like I will be spending a bit more than I thought
Im A Nervous Wreck
DM
