My . 02
Fuel SYSTEM
Lubricity, temperature of feed fuel, correct feed psi and volume, pump tap (holding the solenoid closed longer), driving conditions.
Lubricity - fuel lubricity is the whole basis of lubricating the pump. Some tolerances internally are extremely tight measured in um. Lubrication film is essential.
Fuel is supposed to cool the pump. What temp is your "cooling" fuel. I think you will find OEM fuel is actually pretty hot. I am doing extensive experimentation with fuel cooling and can deliver OAT + 10* cooling fuel unloaded cruise. Stuck in traffic OAT + 30* cooling fuel. All that is after extensive fuel system mods. How hot does your part of the country get in OAT?
Feed fuel psi should be 13. 5 psi (Bosch). The vane pump is the key to keeping the VP44 timing, injection, and cooling functioning. Diaphram deflection is limited to . 5mm before seal damage begins.
Feed volume has to fully fill the vane pump lobe. I do not feel that the stock system design accomplishes that effectively. Hence "big line kits", AN-6 lines etc.
Pump tap. The Bosch book states the starting solenoid amperage is 18 amps, with 10 amps holding current for the closed position. Hold it closed longer, more heat in the solenoid (my thoughts). More heat adds to already temperature sensitive device.
Driving conditions. One variable very hard to get a handle on. I measure the EBC cover and know for a fact that fuel temp has a direct relationship to EBC temp and VP body temp. RPM has a direct relationship to EBC temp and VP body temp. I force OAT cooling air on my VP for engine run time and 128 minutes after engine shutdown. I have thermally insulated all fuel lines in the engine compartment. I have thermally insulated the VP. Fuel return is to the tank filler vent line. 1 active fuel cooler, 2 passive fuel coolers. Removed OEM ff. Another fuel cooling approach is in the works.
Lubricity, temperature of feed fuel, correct feed psi and volume, pump tap (holding the solenoid closed longer), driving conditions all have their contributions to VP longevity (and I just might lose mine tommorrow
Bob Weis
Fuel SYSTEM
Bob Weis
