Do Front Wheel Bearings (4x2, 2000) Require Repacking
Best Buy
new member hard to start truck
Just rotated the tires. The front hub is attached with one large nut that says "Do not reuse. "
Does the 2000 model have permanently lubed bearings or do I have to repack them?
How much does that nut cost?
Thanks,
Bobby
2000, Driftwood, 2500, automatic, 3. 54, 2WD, LWB, SLT, Quad Cab, most of the options, Grover air horns, no muffler, Banks Git Kit, ISSPRO guages, tow 5500lb 28'x8' Aerolite TT and two small boys.
Funny you should ask 'cause I just replaced the wheel bearings on the '95 at 113k. No,they are not sealed "perma lube" bearings . They are an inner and outer just like any old car or 2wd truck. It might be a good idea to check or repack them after 50-75k of hard use,but I don't think it needs to be done as regular maintenance.
When I took off my bearings,they still looked good with no scars and rolled just fine,but the grease seals were toast. I replaced them because one brake caliper locked up creating so much heat that the grease ran out of the hub. Seemed someone drove it that way for a while.
-Mike
forgot to show sig for the '95... .
'00 2500,QC,4wd,LWB,Dark Garnet,6spd,3. 54lsd,SLT,DD stage II,Psychotty air,10-level PM3,Jacobs ebrake,Isspro pyro & boost gauges,2wd-low,Airoquip fuel lines,Smittybilt nerfs,BFG 285/75 AT's
'95 2500,Reg-cab,2wd,LWB,White/Driftwood,Automatic,3. 54open,SLT
Mike, I didn't realize you'd picked up a 12-valver already #ad
Is Emily going to join us for Dyno Day so you can BOMBvoy up there with both rigs?
Vaughn
No,both rigs aren't going,just mine. That 160 horsepowered 12valver isn't worth putting on the rollers... yet! #ad
-Mike
Bobby,
The front hubs on a 4X2 '00 are "lifetime" lubricated. I don't know whose lifetime they are using, but you don't have to repack them.
Look at page 214 in your Owner's Manual, left hand column, about half way down the page, "Front Wheel Bearings".
Bill
Y2K 3500QC, 6 Speed, 4. 10, SLT+, Camper & Tow Pkg. , Westin Chrome Nerf Bars, Mopar Flaps, Reese 20K Hitch, EGT & Boost Gauges, RPM 45 Gallon Aux. Fuel Tank, Highway Products 5th Wheel Toolbox, ECM Controlled PacBrake, Painless Wiring Kit, Mag-Hytec Diff. Cover, Rancho 9000, Air Lift 5000 Air Bags, TOYS: '97 Hitchhiker II 31' 5th Wheel, 2 slideouts, 19,750 GCW, '94 Lance 990 11' 3" Slide-In Camper, Torque-Lift Camper Tiedowns
[This message has been edited by Bill Stockard (edited 03-12-2001). ]
What about the 2k 4x4? Would you recommend them being repacked?
I have 15700 miles on my truck and haven't touched the bearings yet.
Kev
Reading my service manual I seem to remember that we must "inspect" the front wheel bearings. does this mean jack it up and shake the tires? I really dislike "permanently" lubricated anything! I want to service and maintain my truck for the next 500k miles/30 years. My 1970 1/2t 4x4 350ci lasted that long and it was a gasser. 4 engines,2 transmissions,2 transfercases and more tires than I can remember.
2001. 5 2500 ETH/DEE 4x4,Patriot Blue over Silver,Camper pkg, Trailer pkg,Agate Leather,Stainless Smitty Bars,Tow hooks... . Except snowplow!
Great White,
I rotate my tires myslef every other oil change, and while the front end is off the ground, I always check, the wheel bearings for excessive play. I also rotate the hub and listen for any bearing noise. It's a good time to take a look at the brake pads while the wheels are off. On my previous trucks, I repacked the bearings every 30,000 miles.
I plan to continue this practice of checking the bearings on the '00 even though the bearings are "lifetime" lubricated. I'll just omit the repack every 30,000 miles.
I just don't know whose lifetime we are counting for the lubrication. #ad
Bill
Thank You.
I looked at the owners manual and it is as you say.
I should have looked at the manual first.
Bobby
