mwilson
Even without a big camper I would run the bags independent. When it's a single fill port you have one bag, so air moves side to side as the truck sways or leans into a corner. Even empty the truck has some roll on a corner. So when you are loaded (even if it's a equal and low load) and you go around a long corner the air moves from the outside bag, now there is more air in the inside bag and less on the outside. When you stop turning the air takes a little time to move back, so the truck isn't level and what if there is another corner the other way?
You also remove the secondary feature of the bags which is sway control, and as I mentioned can actually make sway worse.
The only people I have talked to that are unhappy with their airbags performance are the ones with the bags plumbed as one and they live in curvy mountainous areas.
Can you open and view this link???
https://secure.freightliner.com/ezw...GM&DiagramPartNo=D12-15908-000&diagramCount=1
If it opens does the control bar at the top work??
If so I will throw my . 02 in... .
Mike.
