Do I need the waste gate hooked up!
Any intercooler gurus out there?
South Bend Luc cluthc....rattling noise
I have a banks turbo on my 93, i think the
threaded item is close to the end, i guess this is at a position so it will only open
late, do i need this vacuum line looked up
my stock turbo did not have waste gate.
is this only for extra insurance?
under normal driving does my gate open up?
i get about 28 lbs boost.
bill
1993 w350 ex cab, banks,nv 4500 in
open exaust, pw Injectors are in. Big rig flaps,tach soon to be in. Its loud and goes ok, for a 93,only beat 1 pwr strk furd. 2 optimas,
love driving it!
I have my wastegate disenabled. It will only let me get 20psi.
  • '93 250 LE 4x4 5spd 4:10 Loaded,dual 5" chrome stacks,12cm² turbo(37psi),PW injectors,K&N,pyro/boost,US Gear E-Brake,tool box,CB,10" AR rims, 285/75/16 Bf goodrich. "wirenut_21529" on Yahoo Messenger
  • '97 Ford B-Series school bus (5. 9 Cummins!)I'm gonna Bomb it!
  • '94 GMC 2500 6. 5L Turbo
PICTURES.
Check my signature - I've got a Banks on my 93 and after I adjusted the waste gate I get 27lbs of boost (same as you). I can adjust for more but I am very happy with my current performance. I would adjust the boost to get better performance. You've got the larger injectors have you "tweaked" the pump to get all that you can get?
1993 250 4X2 - Banks Power Pack, BD Power Injectors, K&N Air Filter, 6 gauges and tweaked pump. 27lbs boost unloaded.
Horton fan & NV4500 5 speed.
I've never hooked mine up been that way for about 4 years I guess.
93 W350 5spd 3:54 gears White 4" stack Headache rack with Lights. Gauges 27pnds boost Banks quick turbo Hand Throttle CB Goosneck ball
yes, if same boost ill leave things alone
i did move the rpm cap and stops
i can go to 3,000 rpm
hope to see some 1st gen in vegas in may
mine will be the one with 5 antenna's
on it. and a red mopar flag on the big
antenna,
bill
love driving it!
