tp0d said:Bobcat:
If you recently removed the axle, its possible a bit of fluid leaked over the seal and is sitting in the axle tube. Try parking with the passenger side on a downhill overnight and see what happens... just may be a bit of residual fluid. . happened with mine.
good luck
-j
RKraft said:I just put some in my uncles 96 and he went to the local parts store. I know you probably know this but you have to spread the case to get the diff assembly out. Good luck sorry I can not help you with part number but he used Motor Parts store here in MN.
