The OEM tow hooks extend forward through the air dam. If your Ram is equipped with the air dam, you will need to cut openings for the hooks. If I remember correctly, the inner surface of the air dam has the opening locations marked. I used a router & home made jig to cut the relatively soft air dam.. . . Looking at a set of Tow Hooks on eBay & was wondering if any fascia modifications are required to installing them. . .
