Wow the translation is rough but here ya go. Oh and no diesel
oh And
Ram Mexico Site
System of Security -
seat Belts of 3 points - forward/rear Antilock Disk Brakes System Equipment -
Softening of heavy work -
Seats with fabric - Crystals color - Step in cabin - fold-up exterior Mirrors of 7 x 10 inches
- Lamps of identification in awning -
Rims LT225/95-17D Expensive black every station - Grill in Dark Gray
color - Rhine of steel of 17 x 6inches - heavy work cooling off System
Technical specifications
-------------------------------------------------------------------------------- . 4000 CHASSIS CABIN
Technical specifications -
Type of motor V8 5. 7l -
Power cf @ rpm 330@4,800 -
Torque lb-foot @ rpm 375@4,200 -
Manual Broadcast of 5 velocities -
Tank of fuel 132. 5 lts. -
Rear-wheel Drive -
Direction Hydraulics -
forward Suspension stiff Axis and 5 arms of control, helicoid springs and stabilizing bar -
rear Suspension Springs of double step and to help -
Height of cabin al flat 700 mm -
Height of step al flat 400 mm -
Wide of cabin 2,030 mm -
Wide of rear axis with rims 2,438 mm -
made out forward 1,770 mm -
made out rear 1,926 mm-
Wide platform obsession points 1,106 mm -
Distance of Cabin to rear axis 1,953 mm -
Distance among axes 4,077 mm - Long 6,142 mm -
Area of load 8. 0 m² -
Capacity of load 3,052 kg -
Traffic gross Weight * 5,682 kg. -
Traffic Weight ** 2,630 kg -
Traffic gross Weight Combined *** 7,711 kg.
*Traffic gross weight: Weight of the aforesaid vehicle in kilograms, added al of its maximum capacity of load according to the specifications of the manufacturer and al of its tank of full fuel. **Traffic weight: Is the weight of the vehicle in conditions of operation with all the normal team of factory and with its levels to its nominal capacity. ***Peso Rough Combined Traffic: Weight of the vehicle but the weight of the trailer.
