Dodge Stratus heater..
VW Routan is a CHRYSLER
Ford f350 rear axle nut
Heater blower only works on high. Is this a switch problem or is there a fuse that runs the lower blower levels??
the lower speeds run through a resistor block, should be visible mounted on the A/C-heater housing under the glove box area with a plug in witing harness. bg
Replaced it yesterday. Hard working with a mirror to see up and under the dash but got it done. HVAC had to be trimmed back a little where resistor goes in since they have an updated part that is slightly larger and should be able to withstand the heat buildup.
