I'll add this, I have read and re-read these same requests for information, over and over and over again. Is this so unbelievable or a task that is extremely difficult to complete(pressure switching and wiring)? I don't think so. The info may not be labeled 47RH, and that could be part of the problem. Any opinions on that welcomed...
I agree it is a relatively simple job to wire in pressure vacuum switches to control these functions, but, think about how you use OD and lockup for a bit and the ranges we deal with in oil pressure and vacuum.
Oil pressure generally runs 25 to 65 psi in the 5. 9 and it is very rpm related. Vacuum is even a lower range as it is driven off a pump not by engine load like a gasser. For the purpose of OD how do you vary engagement based on rpm and throttle position? If we are pulling hard we want to hold off until speed and rpm's are up to preserve the acceleration. Without electronics to overide the normal engage it will go when the preset is reached irregardless of conditions. Then, what happens when OD engages and rpm's drop and oil pressure drops? It is entirely possible to set a pressure switch to the point where it will constantly bounce due to the fluctuations.
TC lockup is even more critical as it is really hard on the input shaft to engage it under power. Unless you do billet shafts, which is a fair chunk of change, you run the risk of popping shafts and making a mess of the trans because of the limited control ranges. A dimmer or mystery switch is fine as long as ALL drivers recognize it and know how to use it, but, aroud mu house that ain't happening.
Let me stress this, I am NOT opposed to mystery or Hobbs switches and some down ingenuity. Both of my trucks have them and even I forget occasionally the lockup is on when stopping. :-laf They are just not very user friendly for a bunch of different people.
Yes, the stand alone controller is a bit expensive, but, it takes the unknowns out of the equation and gives an almost infinite adjustability to conditions and drivers. Everybody from sis to grandma can jump in and go without an in depth education on the workings, do's and don'ts. Plus, you won't have to fix any number of things that can break when an untrained person does the wrong thing.
Ok, dissertation over.
