Does anybody want to sell their stock intake horn?
Where to find TSB's?
Harley is quicker.
I drilled mine for my boost guage, but it has been problematic to keep airtight. I want to use the existing plug on the drivers side of the block for the boost like some of you have done, and I would rather replace the intake horn then put a plug in it. In case you don't know what I'm talking about, look at the photo in the first post to this topic https://www.turbodieselregister.com/ubb//Forum3/HTML/002559.html That part that says "Banks high ram" on it replaces the factory part I am looking for. If you want to upgrade to the Banks, or already have, and have not tossed the OEM horn, email me or post here. Thanks
'00 2500 reg cab LB 4x4, 5spd, LSD, Hot Poweredge, 275 injectors, Warn HS9500I winch, Trans4mer grille guard/winchmount, TracRack, Line-X OTR, G-tech, Loadsaver, and a bunch of other crap I don't technically "need" Name a factory option-I don't have it!
<font color=blue>Why not replace it with the Banks type yourself? Rob said it was only $250? I am sure a new OEM one is at least that much #ad
I drilled mine so even if I did upgrade myself mine is useless to you #ad
Just curious... .
Believe it or not a new one is only $60 from Cummins,heard that here so it must be true.
If fouled up threads are causing the leak why not drill and tap to the next size up and use a brass bushing with antiseize?
Kat,I think you may need more than just the horn to install a Twin Ram,if my memory still works it's more like $850 for the entire setup.
[This message has been edited by illflem (edited 01-22-2001). ]
I agree, why go thru the trouble, hassle?? to replace. Drill and tap to next size pipe thread and bush it or better yet get the nipple for that size thread / hose??
The twin ram intake is only made for the 12 valve. The type I have is for the 24 valve. I have no idea what the twin ram does as far as power/etc increases, but I would say mine is no appreciable difference. Looks only, and not for everyone. Personally, I am glad I bought it!
