Details here: TDR Privileges
I just put an hpfp on the truck and when I start it with the remote the pump does not run. As soon as i turn the key to the run position and press on the brake I can hear the pump start. Does anyone have a fix for this
Real easy... fine a fuse tap that is hot when your remote start takes over the truck. Test with a test light. I would think there is an "Engine" or "ECM/PCM" circuit that you could tap and pull power from. You could also tap power back at the 12V+ that is supplied for the in-tank pump.
