On a 24 valve (2002),
What is the flow rate of the oil system?
What is the micron requirement of the oil filter?
Has anyone ever used the cleanable metal oil filters like the RACOR LFS60 (28 micron, 20 gpm) or LFS90 (28 micron, 45 gpm)? You could clean them more often and maybe get a better oil filtering job done more consistently. They are designed for larger engines than ours, so should work. Would pay for itself over time.
How small in microns should a bypass filter be able to filter? Is there a lower limit that would be too small (1 micron?, 2 micron?, 3 micron?, ... . ) that it may filter out the additive package (do not know even if that is possible). The RACOR LFS 802 says it will filter down to the 1 - 5 micron level at 1/2 gpm.
How would synthetic oil vs dino oil be effected? Any difference in the filtering?
Just kicking around some ideas.
I change my dino (Delo 400) every 5k or about 5 times a year. I realize that part of the oil change is puting in a new additive package and removing particulates that the "regular" oil filter does not get. This is not an idea to not put in a new additive package every 5k, but have a better more consistent filtration at smaller particulate levels. The bypass filter would still have to be changed every xxk miles, but the high flow filter would only have to be cleaned every 5k miles.
Bob Weis
Bob Weis
