2nd Gen Non-Engine/Transmission Does Ext. Warranty Cover AC Evaporator
2nd Gen Non-Engine/Transmission steering/brake problem
2nd Gen Non-Engine/Transmission Does this piece come with the DSS???
kscheffler
In the past two weeks I have noticed a very small amount of water on my passanger side floor matt. I am assumming that my evaporator core is leaking? Or can it just be condensation? Seems like it started when I started using the AC in the past month? If I see water should I assume that I have a problem? I plan to take this to the dealer under my extended 7 year warranty that expires in 2 months I am wondering if anyone has experience with this problem under warranty policies. I have the Dodge extended warranty. I don't have a good feeling about this. Any input would appreicated... . kts
If your evaperator was leaking, your AC probably would not cool and it would be oil on your floorboard. But most likely it's just the drain line.
Actually my AC is not working all that well; it does work but I need the fan on 3 out of 4 to maintain 70F when 85 outside. Drain makes sense; where is it? Thanks guys this is sounding better and better... kts
My truck soaks the floorboard in about 3 days with the A/C on, and I cant figure out how to make it stop either. I blew out the drain with an air hose several times and it never helped at all. Id like to hear a solution for this one too. Ive heard of putting a hose on the end of the drain will help but havent tried yet. My A/C works very well and did last summer too so I know theres nothing serious wrong, I just cant get it to drain right.
