AShelor said:Mine leaked till I put on the Genos drain plugno more leak and super easy oil changes. .
http://www.genosgarage.com/products.asp?dept=24
CogginsP said:Just checked out that EZ plug and thought it looked pretty sweet, might consider investing in that... any other testimonials?
Silver_Ram said:I have changed oil on several different Dodges, & I have noticed that with alot of the 12V & early 24V, The oil pan can be drained when you loosen the drain plug out about half way. The oil literally runs out. When it stops draining, I pull the plug anyway, & its been empty every time. Tighten things up, and no leaks. I don't know if this common on all of the older trucks, but I sure see it alot.
