My 3500 4x4 dog tracks when in 4wd on snow/ice packed roads. .
... only one side spins when on wet grass...
... in 4hi... turn the wheel... the truck jumps up and down.
Blue, Not just every day you and I get to discuss snow and ice handling, is it?
First, educate me on the term "dog tracks" - do you mean tending to follow the ruts vs. driving where pointed, or are you describing something different?
I'm not a duallie, but my observations driving to work two days ago on the interstate were that when I started sliding too much or had to pass someone in the "bad" lane, I was still much better off in 4WD. I didn't feel 100% stable, but I think it was just characteristic of an extremely heavy front and almost unloaded rear, and 4WD was still far better than 2WD. I have since purchased some bags of sand, so if it gets nasty again we'll see if how much difference some extra weight makes.
On your limited slip performance: I have a question for our resident experts - can somebody explain the difference (if any) between the Chevy Limited Slip and Dodge Limited slip? What causes the limited slip to activate - does the spinning wheel have to spin fast? I rode in a Chevy the other night, and we found a ditch that you could drive over at low speed so that the truck would balance on one front and one rear wheel, with the other two wheels almost completely off the ground. If he drove slowly, he got no limited slip action and we could not climb out of the ditch. If he gassed it and spun the rear wheel rapidly, there was a solid "clunk" and the differential appeared to lock almost solid, because the truck then performed like it had a mechanical locker and drove right out. But my key point is, it was not how many times the wheel turned, but how fast it turned, that determined whether or not the limited slip mechanism activated. So it the Dodge like that, do you have to spin the tire fast, or is it more like the Auburn units which I believe build up friction for each turn of the spinning wheel, even at lower speeds? This question is important for all those who feel that their limited slips are not working - first we have to know what "normal" is!
Blue, your last question, about "jumping up and down" - mine does this on soft gravel, but locking in seems to help. I believe our rear leaf springs allow the rear to "wind up" because they allow the axle housing to rotate a bit. If you were going in a circle in 4WD, this could wind up the rear axle because the front and rear axles are travelling different distances; when it finally develops too much force to hold, it will release by spinning the rear tires and you get a hop at that time. If you search old threads on "traction bar" or "bunny hop" you will find some aftermarket devices that help control this tendency, but I have decided it is not bad enough to spend money on. I may change my mind later, but there are other toys I want worse than traction bars! In other words, I do think this hop is normal.
2001 ETH, QC, LWB, 4WD, 3. 54, SPA Pyro & Boost, K&N RE-880 w/foam pre-cleaner, ARE Z-series Cab-high shell, Rear ARB locker, and all kinds of synthetic fluids...
