Dome light, auto locks & reading lights
Do I need additional gauges ?
Dome light, door light auto lock not working
Hi,
I just installed an edge juice and after installation the dome lights, auto locks don't work unless I put the key in ignition and turn to run. I do have a punch of codes displayed, but I think this is from bumping the battery cable to battery when the unit was disconnected.
I've checked all fuse and none are bad.
The trucks runs fine but no auto lock w/fob and dome light with door open or chimes. .
Codes
P2502, P0237, P0477, P0193, P0483, P0217
Any suggestions?
Charging system output voltage, turbocharger boost press sensor low, exhaust press control relay low, fuel rail press sensor high, cooling fan speed, coolant temp too high... wow!
Try clearing all codes, put truck back to stock, see what happens. If all is ok, you can try loading the edge again. That's where I would start. Jess
