I just got done replacing the pins and bushings in the right side door. Door is nice and tight, but is now out of adjustment.
if you look at the door trim it line up on the fender, but at the end of the door its own 1/2 inch and the door will not close.
the adjustment on the hinges where it bolts into the door will only adjust flush fit, not up and down. How is this adjustment made? do I need to shim the hinges? I cannot get to the upper hinge bolts that mount to the body, would have to remove the dash.
Am I missing something simple??
