My driver door was sagging 'cuz the hinge was worn bad!
The fix was a lot easier than I thought. Picked up Part Number 38386 "Door Hinge and Bushing Kit" at the local NAPA off of their 'HELP!' parts rack. If they don't have it in stock it can be ordered.
I pulled the lower hinge, replaced the bushings, and wha-la! Door doesn't sag and closes much better!!! It really was a no-brainer, just took thje time to work through it all!!!
Here's how I did it:
1) First thing I did was prop the door up (I used a couple of milk cartons and a wood block) so it doesn't sag when you unbolt the hinge. If possible, mark the position of the hinge to the door and the body.
2) First bolt out is the hinge to body mount accessible from the outside. You need to use a 6" extension and a universal on your 9/16 short socket.
3) There are 2 more hinge-to-body bolts accessible form inside the vehicle; you need a 9/16" deepwell socket for these two. Unscrew all the kick panel screws except the top 2 (you're not unscrewing those because you can't get to 'em!!! You'll see what I mean when you get in there!!!) Pull the kick panel back, and you'll see an oval rubber body plug; pop that out and you can get to the other 2 hinge to body boles from inside the vehicle.
3) Unbolt the hinge form the door (3 more 9/16 bolts) and take it to your work bench.
4) Punch out the hinge pin, separating the hinge into two pieces.
5) My hinge had very worn factory bushings, which you have to punch out. The kit has 2 replacement bronze bushings which just popped into the same holes (I've heard that in some cases there is no factory bushings and the hole has to be drilled for the replacement bushings).
6) After the bushing are replaced, fit the hinge back together and then drive the new hinge pin back in.
7) Re-install the hinge; I installed the 2 inside hinge-to-body bolts first (the ones accessed from inside the vehicle), then the door-to-hinge bolts, and the last bolt was the outside hinge-to-body bolt.
8) The hardest part is re-aligning the door; the hinge-to-body mating has a lot of adjustment. Take your time, try to line it up with your earlier mark. It is possible - even likely - that because of the slop in the worn hinge you may have to 'tweak' your original mounting positions.
And that's all there is to it!! Took me less than an hour - even in the miserable drizzle that started up after I started!!!
Hope this will helps someone - actually, I know it will!!!
Mike
Mike
