door rattling fixed?
Write up on Jeep Rescue in July/August 04 of Truck Trend
Newbie Alert! Bought a new truck yesterday
Anyone fix their rattling doors?
If so, How?
How hard was it to remove the door panels without damaging those little clips?
Thanks!
Removal of the panel is easy-- built-in hooks on the top that it hangs on with screws accross the bottom. Unscrew those remove door handle and I think there's bolt(s) in the armrest. Then lift and remove.
I have a rattle in mine only if the volume and bass are too high. Some day I'll look into it. Could be speaker, plastic vapor barrier, or lock linkages.
I had the same problem after they removed my DS panel to replace the rubber strip on the top. The mechanic put some doublesided tape inside the panel and no more rattle or vibration wih the heavy bass. Good luck!
If so, How?
Thanks!
Keep lookin' through the back posts. There are several comments on this, including one in the TDR mag one issue back. I think Vaughn Mackenzie may be the poster.
