It seems like a lot of road noise comes from the back seat area. How much work is it to get to the bare back wall and how effective is it to cover that area since the vents back there have to remain unrestricted?
Might want to look at mass loaded vinyl. It weighs around 1 lb per square foot and did a incredible job hushing my truck.
Remember, there are two types of noise: vibration and airborne noise. Use a foil backed butyl mat to dampen vibrations and then the mass loaded vinyl to block airborne noise.
What is mass loaded vinyl?? Where do you get it? It sounds like a combination of what you are suggesting would be ideal, unless it costs as much as the dyna mat... :-laf
This is not being posted in order to hijack the OP's thread. Just answering the question. But there are mountains of info at the following site.
Sound Deadener Showdown - Your Source for Sound Deadening Products and Information
I used the same stuff from Home Depot that RTaylor used under my hood today... not a good Idea. After a quick 5 minute drive the engine heat had it falling off. I even prepped the surface w/alcohol and rolled the material in good... Guess Ill be spending another day taking it off and cleaning it.
Well, It's almost been a year now and I am still very pleased with my low cost results. There is no smell what so ever as it was gone after the first month, We've had 3 days of 100 to 106 degree weather, no asphalt smell or goo dripping off the bottoms of the doors. I took a door panel off to inspect it, No sagging, running or melting. It's still exactly where it was stuck on.
R.Taylor, Nice write up. Its been a good few years now. How is the material you used holding up? Did you ever have any issues caused by heat?
