Details here: TDR Privileges
if i were you i would try and run 3/8 id lines and get rid of the Banjo fittings, and free up the fuel flow, you can make all your own lines and fittings.
Great! So just clamp off a flex hose after tank and remove the line from clamped point to fuel filter - hook up new pump after the clamp and run the new ?psi hose to the fuel filter...
