I changed my oil yesterday, for the second time since I got the truck last October. I'm a tad under 8000 miles, and the last change was at 4000.
After emptying the contents of my drain pan into gallon jugs, I noticed that it only filled two jugs (including what came out of the oil filter). I know I put 10-11 quarts into it last time, so that means it's down about two quarts.
Does that sound normal for the first 8000 miles?
Also, I noticed some oil residue on the bottom of the transmission immediately behind the oil pan. I'm wondering if I have one of those leaking oil pans. I wiped it off, and will look again in a week or so to see if it's returned.
So far, fuel mileage remains the same... low 14's unloaded, even with the addition of the DD3's.
Rob
2001. 5 RAM 3500 QC 4x4 ETH/DEE Silver/Agate, 4. 10, USGear OD, Rickson 19. 5 Wheels, DD EZ, DD3 Injectors, SPA Guages, Psychotty, Firestone Airbags, Hellwig Rear Swaybar, Torklift Superhitch & Camper Tiedowns, Mag-Hytec Diff Cover, DD 4" Exhaust, US Gear Exhaust Brake, etc. On order: Southbend Clutch, HX-40
Rob
