Downpipe flow question
16 cm housing swap out
Installing Steering Shaft
"Mad Max"
Folks, I'm trying to get smarter on downpipes and perfromance. I'm planning to upgrade the exhaust on my '93 to a 4" system, and I'll make it all myself, but I have a question on downpipe flow.
I'm planning an upgrade to either a 16 or 14 cm housing behind an HX-35, and I can make any custom downpipe, but I wanted to know if it matters how the exhaust exits the turbo, meaning is a tapered downpipe (from the collar to the full 4" pipe) better for flow, or just go directly from the collar diameter directly (non-tapered) to the 4"?
Here's an illustration:
Direct to 4": #ad
Tapered to 4": #ad
I can make either, and both are as easy as the other, but from a performance standpoint would the tapered make less turbulence than the direct method? Thoughts?
Many thanks,
- M2
Just go to 4" @ the elbow. The connection will not matter, it's the short radious 90° elbow that is the restriction if your pushing a great deal of exhaust/ flow.
I'd bet a case could be made for tapered, but in practicality I doubt you'd notice any difference. Since it's easier, go straight.
Jay
Anyone have a guess as to what kind of air speeds we're talking about in the DP at WOT? If it's as high as I think, a tapered design could be very important. Here's a good closeup of Stan's 4" DP...
I think I still have a picture of mine in the reader rigs. I simply cannot recall if my DP is tapered or not... ... ... ... ... my truck is a lawn ornament now.
Sam. We could pull the DP off of "Red" for the weekend. I want to build one for the Dually too, so... I have pics too.
Red's DP is like the first pic. Just built a "donught" from a piece of old /4" framerail. Used about 1-1/2" of the original 3" DP. Built the "donut" to fit inside the 4" and made the center big enough to accpet the original DP piece. I originally did the taper, but you can run out of room pretty quick. The 4" takes some space.
Let me know!
Thanks!
I forgot to mention that all the buses have a 3" DP and then the 3" to 4" adapter. I obtain my adapters from a number of sources. Some are a blunt 3 to 4 and others are a gradual taper.
I build my own school bus exhaust systems and use either/or. Whatever I have in stock @ the time.
The picture above looks similar in shape to the one on my 91. Looks were a different story. But I did notice a definite drop in EGT and gained a few psi boost. Cooldown was quicker to boot.
I vote tapered.
Daniel
