Fireman said:
You're so right Ryan ! The fuel line came right off, but the return was turned to where you couldn't get your fingers on one of the tabs. I would have given$100 for that tool at that time.
Fireman
I bought the Summit fuel line disconnect tool and it already saved my neighbor's life! It is a very high quality kit and makes "quick disconnect" lines very easy to work on with no pain and frustration. I recommend it to anyone planning on any fuel system modifications.
[Disclaimer - I have not yet had need to use the tool on my truck, so I'm just assuming it will be equally useful on it as it is on other quick disconnects. ]
Kry226 - I had the same question about high pressures damaging the CP-3. I don't think there's a problem, though, as there are a number of people on here running 20psi (or more) to the CP-3 without experiencing any problems. I built a pump controller circuit for my aftermarket pump, so I can change pressures at will. Adjusting pressure at idle has absolutely no effect on the engine whatsoever. The Fuel Control Actuator mounted on the back side of the CP-3 automatically determines how much flow to send to the CP-3 for cooling and engine supply, then dumps the remaining fuel to the return line.
I have also turned on my pump and run up to 15 psi with the key out of the ignition without causing any damage to anything (I had some fear that if the FCA was not energized then pressure at the inlet to the CP-3 could damage it).
I do think (and this is just opinion) that the flow rate to the CP-3 should be regulated to prevent
too much quantity. First, a pump with a very high flow rate can cause cavitation problems when used with the stock pickup assembly. This will significantly shorten the life of the pump. Second, the return line to the tank is an 8mm (0. 315") OD stainless steel line, so it's not that large. Exceeding it's capacity might cause some sort of harm - probably directed at the FCA (note the supply line is 3/8" OD).
I am now running an Aeromotive 11203 pump which (as I mentioned) has a pump controller circuit since the pump can flow around 150 GPH at free flow conditions. I really think that for stock trucks 95 - 105 GPH is about maximum you want to flow to keep things "reasonable" (factory minimum spec on 2003 trucks is 38 GPH). The 95 GPH FASS pump, then, is perhaps an ideal choice (except the price
). Obviously, power enhancements may dictate a higher capacity pump. I really think the key is balancing the engine demand and the return line capacity.
-Ryan
