Dr. Peformance Camshaft Kit
Installed ISSPRO Turbo Temp Monitor
Does Cummins have ownership in Lucas Oil ?
I just wish I did not have to spend another $2500 to drive to Vegas and back to get it. That is the only reason I can't have one.
Oh ya I am going to the dragstrip tommorrow with Floor It... to make some runs. Once I get my numbers I'll have a better idea of how everything is working. I couldn't really use the Vegas numbers for comparision due to the temp and altitude, but I ran 13. 58 out there. This is at 6480lbs.
I'm hoping to see 13. 2x tommorrow.
I gotta get out of the "hotrod" mode before I can compare fuel milage.
camshaft
hey joe d. I really enjoyed my visit to DD and to finally get to meet you. I have seen first hand what DD cam can do. Fred Swanson had one put in, and he loves it. The Cam really reduced his EGTs, and increased his spool up quite a bit, And cleaned up his smoke dramatically.
All I can say when money allows, a cam from DD will be my next MOD. Chris this one is a winner
Kat,
I had read your post where you said the chips in the Comp had been changed, but when Joe "let it to the wondering mind" where the "133" hp came from, I just wanted to use your case as an exapmle, sorry if it offended you. :(
Andrew
OK, OK, I admit I was stirring the pot a bit with that 133 hp stuff :eek:
I am trying to drag everyone's attention to the fact that it takes a well-working package to make big hp, not certain bolt on parts by themselves. However, I haven't heard ANYONE with the DD cam have anything bad to say about it.
Joe,
YOU stir the pot?!?!?!:eek:
Would YOU want to spend $2500 then admit that it didn't do much?!?!?! :eek:
Andrew
P. S. Just pulling your chain, i want one too!:D
Originally posted by TxDieselKid
I just wanted to use your case as an example, sorry if it offended you.
Not offended in anyway, just wanted the info to be correct is all.
Once I get to the dragstrip I'll see how the cam has helped me ..... thats how I do my "testing".
