Engine/Transmission (1998.5 - 2002) drag comp, mach 4.5 an usb turbo what h.p.?
Engine/Transmission (1994 - 1998) Medium Duty Exhaust Manifold
Engine/Transmission (1998.5 - 2002) what should my egt's be?
wonderin if anyone is runnin this combo or similar? what kind of hp an tq. numbers are u seeing? also what kind of dyno did you use? im runing a drag comp usb turbo (bell turbo), an don m 4. 5 injectors. thanks in advance
Two TDR members lately have done this:
Dodgezilla HX35/40 hybrid, drag comp, Mach 4's = 501 HP
B-1, drag comp, Mach 4's = 522 HP
Both numbers are uncorrected on a DynoJet
With Mach 4. 5's , drag comp and this turbo, you should be in that range
or higher.
I Have A Buddy Who We Just 6 Months Ago Put On A Hloset 40, Drag Comp Box Injectors. He Is Running About 502 Hp And I Don't Remember Exact Ft/lbs But That Should Give You An Idea.
