Engine/Transmission (1998.5 - 2002) Drag comp or ttufm
Engine/Transmission (1998.5 - 2002) Power combo....Need opinions!
Engine/Transmission (1994 - 1998) HX35-40 Turbo Non wastegated
just whated to get your opions on whitch box to get. I do some heavy towing in the summer and run dd injectors. Iam hearing the ufm has less timing and has a life time warranty sounds good to me. why would you get a drag comp over the ufm?
drag ufm
how much hp would I gain with the drag ufm on a 02 eth?I think I heard some one say you would only gain about 30hp over ttpm,is this true :confused:
Keith will take care of you... for the cost difference the UFM is the way to go... (and might as well get the Drag version. . ) the ability to change levels is great. . especially with injectors and if you are going to be towing... I tried an EZ. . (Edges version of the TTPM). . is it was better than stock. . but not even close to the power of the UFM... If have a TDR member close that has and EZ or a TTPM barrow it for a test drive... or if you are close to a DD or Edge Dealer... if they are a good dealer. . they should let you test it. . it only takes a min to install... The UFM is a little more involved. . and once the wire is tapped... . (Well. . hangon. . )
I run my UFM on 3x5 most of the time. . only 5x5 for needed times. . or for some :D :D 's I don't have my DDIII in yet. . this week. . and a clutch for the new year... As far as the settings. . I can tow anything on 3x5 and keep the temps in line. . on 4x5. . I have to watch the EGTs . . (The injectors will change everything. )
Good Luck
Bryan
Keith correct me if I'm wrong. .
The DD unit has a bit less timming advance than the Edge unit [a bit better IMHO even though I have the Edge unit]
