Next oil change turn the washer over so the rubber side is towards the pan. The oil plug will turn easier on the steel side and the rubber will seal against the pan.
If you already have it that way, replace it. I think they are $2 or so from Cummins. You should also keep a spare pan gasket, oil filter and fuel filter in the cabinet. My experience and thoughts
-John
