Dreaded right front tire wear
OVRHEAD message/temp/compass
Trouble with Service Dept.
All:
I've struggled with a slight right pull since new and have done the dealer visit thing 3 times for alignments and gotten the regular "it's within specs" comment, rotated tires etc etc to no avail. I've reached the 36,000 mile mark on the truck and as a result on now being my own warranty shop I recently added a Lorenz 5100 suspension setup along with the Dynatrac free spin hub conversion kit. It's time for new tires and I would like to finally try and address both the right pull as well as the right tire wear. I've done the search and although this subject has been covered in quite some detail most of the information is rather old.
When looking at the truck from the front there appears to be excessive +camber on the right side... . always did but the alignment guy says, "it's within spec". I commented that Ray Charles could see that the right front appears to have excessive camber... . no luck... I lose. I would like to know, based on real world data, what is the appropriate front end alignment specs that our heavy trucks should be setup to in order to achieve both the best tracking path and tire wear. Also, if anyone can recommend a shop in the Houston, TX area that has knowledge of our unique Dodge DNA of right pull I would greatly appreciate it.
Thanks in advance for any help!
Jason
My 04 2500 4X4 does it too. I just keep the tires rotated and deal with it. I got the same response from the dealer and an independent on the specs.
Mine is a 2wd and had a pull to the right just a bit. At about 12 miles the tire started to feather. Took it to the dealer and they realighned the front in. Lawrence Marshall in Hempstead. Gordon is the on I talk to when I need something. Very satisfied so far with them.
Update on pulling right
All:
As I mentioned earlier, I've struggled with a slight right pull and right front tire wear since new. I've been to the dealer numerous times trying to get the alignment right to no avail. I've rotated tires from one side of the truck to the other... experimented with different tire pressures and the way I dress in the morning trying to figure out why my truck pulled right. Well, this weekend I finished installed the Dynatrac free spin hub conversion kit and guess what... ... ... ... ... ... ..... the truck now has a slight and I mean slight pull to the left Oo. :eek: Go figure!!
However, I can say that the truck drives and rides much, much better then before. Especially in the 40-70mph range where before the hub installation there was a noticable amount of vibration that you really don't know is there until it's not there anymore and your like... ... . wow... now that is smooth!!
Cheers,
Jason
