DGamelin
I don't buy that shutter can't be fixed. I work on to many trucks that don't have any shutter, including my 93. I think I found the problem. I have been shimming up and down. Couldn't get it much better. Left it at 3/16 down. Started taking measurements. The problem isn't with up and down it is side to side. The motor sits about 1. 5 in to the right side of the truck. The pinion is about 3/4in to the right. And the center support is in the center of the truck. While the u joints shouldn't have problems up and down if you add side to side you can't keep input and out put parallel. I took a string from the rear yoke to the front yoke the moved the center support to the right until it was straight, up and down will give sufficient u joint movement alone. I think my shutter is gone. Haven't towed yet. But I did put my new sjr in and well let you guys know what happens next.
