promisedland
G-day everybody! I would love some info on drive pressure gauges.
Does it work to use a ''non'' liquid filled gauge??
I have seen copper tubing in a spiral then connected to poly tubing then in the cab. I assume this is to help stabilize the needle. I had a 'dry' gauge on my tractor [boost] & it was almost impossible to read the gauge, so liquid it is! I prefer a dry gauge..............
What psi is enough?? I dont want a 100psi if 60psi is good. a turbo upgrade is on my list as the he351cw [i hear] is known to cause high dp...
THANKS!!!!!!
THANKS!!!!!!
