I've seen a LOT of driveshafts, even built quite a few, and seen some really cockamania crazy combos of pipe and splines!!
Really, you haven't given me much detail... . is it a one-piece, with a slip yoke bolted to the rear diff? Or is it two piece with the slip yoke just behind the carrier bearing? With the slip yoke bolted to the diff, it can help eliminate some harmonic vibrations from low gearing, and helps with axle wrap under torque. If it is a one piece, is it(the yoke) bolted to the back of the t-case?
I've built some Jeep driveshafts that have slip yokes on the diff and H-units(double u-jointed) on the back of the t-case to help with the harsh angles. The newer, larger CV joints are really nice, too, just more expensive, to build and replace... ... Got a pic?
