Hey Guys, the fix is easy and cheap!!
I'll do it by numbered steps, as I just finished this project.
1. Look under the seat cushon and find the four screws that fasten the bottom to the frame.
2. Remove the screws and take out the entire seat bottom.
3. Place seat bottom top down on floor (living room carpet is a good place to do this!
4. Seat fabric (shell) is held in place by 5 'u' shaped pieces of plastic(retiners). Push down on the seat frame and pull the plastic retainers off the frame starting at the back of the seat.
5. Do not completely remove the shell from the foam cushon, it is velcroed in two places, and has hog rings in a third location, leave them alone also.
6. Cut a piece of carpet the same size as the bottom spring assembly, aproxemately 14" X 16". This MUST be good carpet, not rubber backed.
7. Place the carpet with the backing against the spring. At this point if you want to add a little lift to the seat, you can place a 2 inch thick piece of foam rubber, aprox. 16" X 21" between the carpet and the foam seat base.
8. Place the seat again upside down on the floor, place the new foam on the cushon, (if used) use the spring marks to line up.
9. Place the piece of carpet on the foam, nap against the foam, with the backing up.
10. Place the seat frame on top of all the above and line everything up.
11. With a helper holding everything together, pull the sides of the shell up and attachthe retainers to the frame, starting with the front of the seat and then the rear, and then both sides.
12. Re install the seat base and go for a ride.
I think you'll be happy with the results, and still have the $100 in your pocket that a shop would have charged!
If you have any questions, e-mail me.
Good luck, Denny
