Drivetrain rattle?
question for super phat shaft owners???
Can anyone tell me what blow by is?
BTW, is it normal that the drivetrain seems loose, I mean when I depress the clutch the thing rattles like the trans is going to fall off. Felt like that there was no transmission mount. I have tried twisting the drive shaft by hand and there are some play in the rearend. But when I am in the truck it sounded like something in the transmission itself. It shifts fine. Thanks.
The rattle is most likely the throw out bearing or the pilot bearing since it only occurs with the clutch depressed.
I have a muffler off a 05 with a small dent in the corner from being removed. Won't effect its use. Where are you located, I am in south west Mo. near Branson.
Actually, mine has rattled since day one... hasn't seemed to affect it.
Same question, where are you located... I'm in NW Pennsylvania. You can have the muffler (but not the tailpaipe or the Cat since I may reuse them someday!).
steved
