driving lights
jrdeuce:
i've just been working on my lights, sooooo... ... ... i'm pretty conversant with the rascals. i don't know about the steering column area, but i suggest you pick up your feed under the hood. PROBLEM--dc chose to use a switched ground for the lights. do it as follows: if you have a test light or voltmeter, find out which wire in the harness is grounded when the high beams are on. if you leave the light switch off all leads should be hot, or have 12v +. when the lights are on high beam, one of the wires iwll be a ground. use one pole of your meter or light on the positive of the battery and probe the leads. whichever one lights the light or completes 12v on the meter, is the switched ground. now, to wire the relay, put a constant 12v+ to the 12v+ switched lead on the relay. tag into the ground you found at the wiring harness to the ground lead on the relay. battery and light load, wire as usual.
while you are at it, why don't you upgrade the wiring to your lights, and get rid of the 18-20 ga dc used?? pm me if you need more info
herb
