Drop in Air Filters?
Smarty Jr. loaded and question
Quadzilla Mileage Max
I think i'm gonna go with a drop-in type air filter...
These are the 2 i've been looking at and was wondering if what would be the difference in the 2 and which one would be better over the other and why?
Also if there is any other filters i should consider let me know and why? THANKS
1st filter AFE stock OEM replacement.
advanced FLOW engineering : Review v3 :
2nd filter AFE IFR.
Those are the 2 styles i am looking at... Also which would be better a oiled or a dry filter.
Aside the air filter question... . Is that new AFE blade runner worth while buying for my mostly stock(for now) truck?
Either one of the AFE filters is a good choice, the oiled filter is going to give you better protection, no matter what anyone says, I have never had oil residue in my intake.
The AFE dry is also a great choice, easy to clean, and does a fine job.
Amsoil also makes a good dry filter.
Dry filters are going to have to be looked after more often.
PS: What happened to your 07? And the MegaCannon?
Personally, Iv had good luck with Amsoil dropin Im running.
I feel that when someone asks a question like you did, your going to get a lot of different answers.
Each will depend on what works or doesnt work for the individual answering.
Do yourself a favor and search this forum and others on that Amsoil air filter. I threw mine in the garbage can.
I modified my factory intake and added a cold air intake to bottom side. I just placed a K&N in service a like it a lot. I have run it about 500 miles and turbo side tube is still very clean.
I'm thinking of going with the PSM cold air intake with pro-guard 7 air filter in the OEM air box for my 2007. 5 6. 7liter cab=chassis. Has anyone out there had any luck with this combination?
I did it in my truck and it works great. I even extended the tube to the front of the bumper so I get a ram-air effect. The turbo whistle is pretty cool.
Does any one besides K&N make a drop in filter Like that for a 6. 7 or are they all panel filters?
Yeah I realy like the looks of the new k&n!! but Im still on the fence about a drop in or an air intake?? I would like to have a drop in with a diffrent intake hose, like cool blue makes but man they are high for just a piece of hose!!
save your money and just get a drop-in, tdr/diesel power (i think) did a dyno test and the most you would ever gain is like 8hp, the stock system is the best for the money.
I agree totally with the K&N dropin and stock air box with my cold air mod with factory intake pipe with baffle removed. When Cool hose comes out I plan to add one for the looks.
I got the AFE proguard 7 super stock drop-in for mine, and also did the "home-made" cold air intake mod to my stock air box. In addition, i busted out the baffles out of the intake tubing as well. The end result was a noticeable difference in power and throttle response. I would definitely recommend it!
