Drop-In Fuel System for 2010-2018 Ram - from FASS
Killer Grid Heater Upgrade Kit - from BD Power
TDRComm
Staff Member
FASS DROP-IN FUEL SYSTEM FOR RAM 2010-2018
The FASS Drop-In Fuel System (DIFSRAM1001) was engineered to be the most effective filtration solution for the 2010-2018 Ram Turbo Diesel. Without proper fuel filtration, modern diesel injection systems are prone to excessive wear. By removing over 99% of the water from your diesel fuel, along with entrained air and debris down to 2 microns, the FASS Drop-In system protects the injection system from premature failure.
Additionally, by eliminating the contaminants mentioned above, our Drop-In system for the 6.7L Cummins optimizes MPG (results will vary), restores horsepower, and sharpens throttle response. And if reliability, optimized MPG, restored horsepower and a sharper throttle response isn’t enough, this system can be installed
in an hour or less!
This is a true plug-and-play system, requiring no cutting, wiring, or additional modifications. Our industry-leading water removal capabilities (3rd-party proven to exceed 99%) are reinforced by the unique design of our Extreme Water Separator (XWS). If our XWS reaches capacity, it acts as a dam, shutting down your truck and preventing major destruction of fuel system components.
Part Number: FASS_DIFSRAM1001
Price: $479.00
Available at Geno's Garage: www.genosgarage.com
Manufacturer Contact:
Diesel Performance Products (FASS)
16234 Hwy 0
Marthasville, MO 63357
Tel: 866-769-3747
www.fassride.com
