I recently purchased a solid steel steering stabilizer and prior to installing the stabilizer I noticed the FL 205 bearing does not seem fully seated in the flange (actually seems to be tilted) and center hole in the top of the bearing seems off-center (the bottom doesn't). Is that normal or should the bearing be seated evenly inside the flange with the hole centered in the bearing?
